any body running tpi w/11.0.1 with cast heads
Old Mar 18, 2012 | 08:43 PM
mackjar66's Avatar
Car: 1989 GTA
Engine: pending install 383 tpi
Trying to find anyone that's running 11.0.1 compression with cast heads and tpi. How well does it run,setup, ect ect
Old Mar 18, 2012 | 08:58 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: any body running tpi w/11.0.1 with cast heads
I have, and I know several people who have. It used to be quite common on dirt motors (not the TPI) before such a large selection of cheap aluminum heads came to be.
Why do you ask?
11:1 is very efficient with iron heads, though you can run into a problem with heat build-up if you're doing this with an emissions engine.
Keep the engine on the cool side ( around 180* ), keep the exhaust out of the intake manifold (exhaust crossover for EGR), and take some time to get the spark curve set up just right. For a performance engine you want to run a colder spark plug. I would recommend one of the Autolite plugs of racing design that sheds heat quicker.
There's a link to spark plug info in my sig.
There are people who have tried to run high compression with iron heads on the street and end up overheating because they run too much octane and a tune that doesn't match. When tuned correctly and the intake charge kept cool, then you can run on 87 octane with no problems.
If you run emissions equipment and are sticking to a stock chip/tune, then may have to run 92 octane and still have some issue with detonation when the engine gets hot.
Old Mar 18, 2012 | 09:05 PM
mackjar66's Avatar
Car: 1989 GTA
Why do you ask?
I ask bc I have a 355 but 305 heads. I havent been able to source a set of 64cc heads to keep my compression lower. the 305 heads have the 1.94/1.50 valve and some port work. as far as egr goes i was going to delete the whole system and run a 210/214 duration cam with a stock chip, long tube true dual exhaust
Old Mar 18, 2012 | 09:26 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
No problem except for the stock chip.
I highly suggest relying on a good tune instead of luck to keep you out of detonation.
Find a really good tuner and you could be driving and racing on 87 octane.
It will be worth the trouble.
The 305 heads with 87 octane should produce very good fuel mileage once tuned correctly.
Old Mar 18, 2012 | 09:29 PM
mackjar66's Avatar
Car: 1989 GTA
thanks only issue no one tunes anywhere near me. all im trying to find is a set of 083 heads to get this car running with no issues
Frozer!!!
Jan 19, 2024 04:55 PM
Fast355
Dec 2, 2016 06:33 PM
camaro71633
Sep 1, 2015 10:24 AM
86IROC112
Aug 17, 2015 02:00 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
