unplugging est lead
Old Mar 19, 2012 | 02:12 PM
dez58pop's Avatar
unplugging est lead
if i un plugged the est lead tan and black wire lead would it cause the engine check light to come ,i plugged it back in now to check if light goes out but my batt has died now ,so i carnt check at the moment
Old Mar 19, 2012 | 02:37 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: unplugging est lead
Yes, unplugging the EST wire will cause check engine light. Disconnect battery to clear code. Your dead battery probably isn't dead "enough" to clear code (ha, ha).
Old Mar 19, 2012 | 02:42 PM
utilityguy2's Avatar
I believe so. If battery went completely dead or you disconnected the battery it would remove any stored codes anyway. So, just charge it up and see. By the way, unplugging the timing wire just removes the ECM from making any timing changes, unhooked it would revert back to whatever intial timing is set on your car. usually 6 degrees BTDC on a 350 map engine. You don't "hurt" anything by unplugging it. you wouldn't want to drive it that way though.
Old Mar 19, 2012 | 02:43 PM
LOL I took too long typing.
Old Mar 19, 2012 | 02:44 PM
dez58pop's Avatar
cheers guys
ZEEYAA
Apr 16, 2023 08:29 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
pacoelrapido
Sep 11, 2015 02:41 PM
