What's involved in replacing the speed sensor?
Old Mar 26, 2012 | 09:03 PM
02v8ta's Avatar
Car: 1984 Camaro
Engine: Crate 350
Transmission: auto
Or wheel speed sensor i think it's called? After a buddy checked my camaro out we figured it might not be shifting properly because of this sensor. So what exactly needs to be unbolted and where? Thanks.
Old Mar 26, 2012 | 09:08 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: What's involved in replacing the speed sensor?
Originally Posted by 02v8ta
we figured it might not be shifting properly because of this sensor..
There is a VSS that sends speed info to the computer
But in '84 the trans is only controlled by the TV cable ; not the computer
Old Mar 26, 2012 | 09:14 PM
02v8ta's Avatar
Car: 1984 Camaro
Engine: Crate 350
Transmission: auto
Good to know, I also didn't think the shift was off. But he wanted to replace it so that wouldn't even effect anything
Old Mar 27, 2012 | 12:22 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
There is a governor in the trans that affect shift points ; maybe he is confused with that.
It sometimes gets jammed up and sticks , often all it needs is removing and cleaning
Old Mar 27, 2012 | 12:28 AM
Andrew James's Avatar
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
For the two cents worth, a speed sensor on these cars, or at least in the case of my Formula takes maybe ten minutes. Disconnect clip, unbolt from trans, bolt new one and push clip back in. (T5)
Old Mar 27, 2012 | 07:14 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
82-89 Camaro VSS are placed on the rear of the cluster, 90+ on the tail shaft.
JamesC
eightsixseven
Dec 16, 2024 01:50 PM
Vintageracer
Jan 10, 2020 05:33 PM
91REDZ28VERT
Aug 18, 2015 10:16 PM
92purpz28
Aug 11, 2015 02:30 PM
