please help ! tbi to tpi ! help please !
Car: 89 Camaro R.S.
Engine: LB9 5.0 (lt1 cam)full exhaust..
Transmission: WC T-5 pro5.0 shifter zoom S/s
Axle/Gears: 9 bolt, 3.27's
ok here is my problem. I have a 92 rs with tbi/m5, everything is mostly stock, all I've added is headers and pro 5.0 shifter. I just bought a tpi set up complete heads, lt1 cam , full tpi system wiring harness, and computer. it is also from a 5 speed car and it is also a 92. I cut all the wires near the drivers side because I could not take that connection out. I've seen that part referred to as a bulkhead? will the tpi harness splice into those ?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: please help ! tbi to tpi ! help please !
are you asking about c100 ? It's not wise to do splice connections especially in a area that is exposed to moisture.
Car: 89 Camaro R.S.
yes I had no choice but to cut the wires from it, we could not take it out, that car is long gone, will it splice into place
Engine: Lb9
Transmission: M20
looks like if that is the only harness you have solder and shrink tube is the answer for you.
Car: 89 Camaro R.S.
yeah, I hope it wouldn't have to come to that... this should be a fun weekend.
thanks for the help
thanks for the help
Engine: Lb9
Transmission: M20
This is not a specific to tbi or tpi as you can see in the pinout. you can hit up a junk yard or ask the guys who are parting out cars in the classifieds for this section of the harness.
Car: 89 Camaro R.S.
so my current engine harness connector needs to be changed? I cannot cut it the same way as the tpi harness?(just to be clear, these wires are located kinda close to the fuel pump relay s)
Car: 89 Camaro R.S.
same year harness
evilstuie
Jan 9, 2020 08:29 PM
Sanjay
Aug 12, 2015 03:41 PM
