Whine without supercharger?
Old Mar 29, 2012 | 11:37 PM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
I noticed my car, 305 tpi, has a whine when I really get on it. I noticed this whine after I bought a new belt and pulley for the car so I could bypass the smog and a/c pump, but still have them on the car incase I need to pass emissions. Any ideas what it could be?
Old Mar 30, 2012 | 06:45 AM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
Re: Whine without supercharger?
could be caused by a lot of things. it may be a bad bearing in one of the driven components like your alternator or PS pump. a good thing to have, and you can get them at most parts stores is an automotive stethoscope. usually pretty cheap too. looks like your dr.'s stethoscope except it has a long rod that you place against engine components to listen for what ever.
Old Mar 30, 2012 | 07:44 AM
Dakota W.'s Avatar
I just use a screwdriver, no need for all that fancy equipment. They sound fine internally, I just thought it was weird that my old belt was quiet aside from a waterpump squeek when the car is cold, maybe the old belt was loose and now that the proper tensioned belt was put on it is showing the problem that has always been there? I'll just wait until something stops working, most likely the power steering...
Old Mar 30, 2012 | 08:04 AM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
I just use a screwdriver, no need for all that fancy equipment......................... I'll just wait until something stops working, most likely the power steering...
the stethoscope i have costs $12.00. i was a believer in the screwdriver method too until i tried the stethoscope. i also use the "wait till it fails" technique. only on my car though. i have to stay ahead of the repairs on the wife-mobile. lol.
Old Mar 30, 2012 | 08:14 AM
Dakota W.'s Avatar
Hehehe my gf has a 69 RS and is also quite the car enthusiast, it's hard to get her to not touch my car lol. So I'll stick with my screwdrivers and waiting until it fails.
Old Mar 30, 2012 | 08:36 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Pull the belt off and see if its a acc causing the problem. If the noise stops with the belt off you have narrowed it down. If its still there yo may have a trans pump going bad.
I'd check the power steering fluid level 1st tho.
Old Mar 30, 2012 | 08:50 AM
Dakota W.'s Avatar
I know it's an accesory because I ran the car without a belt on it and it was quiet, just need to narrow down the accesory, I'll check the PS fluid when it's light out. T5's have pumps?
Old Oct 8, 2012 | 10:24 PM
kendalljmeyer's Avatar
Car: 1989 Camaro RS
Engine: 305 (swapped)
Transmission: 350 auto
do you remember what size belt you used to bypass the a/c and emissions? and did you use a a/c deleter pulley or just bypass it? i have a 305 and looking to delete both of these. thanks
toronto formula
Nov 10, 2015 06:17 AM
thejimsterz28
Sep 30, 2015 08:52 PM
-=Z28=-
Sep 24, 2015 10:21 AM
Youngs92
Sep 23, 2015 11:29 AM
anesthes
Aug 24, 2015 08:32 AM
