Found this lying around the engine bay
Old Mar 30, 2012 | 10:15 PM
KuroNeko's Avatar
Car: 1986 Firebird, 1992 camaro
Engine: 79' 350, 89 305
Transmission: TH400, 700r4
anybody have an idea as to what the purpose of this was??? it wasnt connected to anything
Old Mar 30, 2012 | 10:33 PM
88 Z-ROC's Avatar
Car: 88 IROC-Z (L98)
Engine: Edel. Lwr, SLP Rnrs, Ported Plenum
Transmission: 700R, 2800 Stall
Axle/Gears: 3:42 Posi.(4th gen.) UMI R/Susp.
Re: Found this lying around the engine bay
Kinda looks like a knock sensor plug..
I dont understand why they were bound that way..
Old Mar 30, 2012 | 10:44 PM
KuroNeko's Avatar
i dont know... theres somany unused wire in there, its crazy. but this was the one that made me acctually laugh
Old Mar 30, 2012 | 10:51 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Knock sensor plug with resistor mod to make it less sensitive.
Old Mar 30, 2012 | 10:57 PM
KuroNeko's Avatar
is that good or bad? also where would it even plug in at?
Old Mar 30, 2012 | 11:05 PM
BigBadCamaro's Avatar
that is the plug for your ac compressor and im guessing it was removed.
Old Mar 30, 2012 | 11:09 PM
tubbytownsend13's Avatar
Car: 87 iroc
Engine: mostly stock 5.7
Transmission: jasper stage 2 700r4
Axle/Gears: stock
ac compressor, knock sensor looks like your fan switch plug not like that..
unless of course your car is like mine and some previous owners hacked shtuff all over the place....i had a maf pigtail for a o2 sensor plug...
Old Mar 30, 2012 | 11:14 PM
KuroNeko's Avatar
yeah,when i got it the PO had lost intrest and didnt hook up the compressor (and im just taking a/c out completely)
Old Mar 31, 2012 | 12:05 AM
88 Z-ROC's Avatar
Well if it works, its not that bad..
there one on the pass. of eng block.. and maybe the oil pres. snsr on driver side..
Not 100 though
Old Apr 2, 2012 | 03:26 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
That connector, on my car, is for the temp switch in the head (pass side) or for the knock sensor (same side).
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
bjpotter
Aug 12, 2015 06:06 PM
jahblah
Aug 12, 2015 05:54 PM
antares57
Aug 6, 2015 07:47 AM
