OBD Codes - What to do?
Old Apr 1, 2012 | 01:23 PM
92GTAkid's Avatar
Car: 1992 Trans Am GTA
Engine: 305 5.0L
Transmission: Manual 5-speed
I used an OBD reader from Innova, the 3120b that does OBD1 and OBD2, and got two codes:
032 - Exhaust gas recirculation (EGR) valve diagnostic switch - closed during engine start-up or open when EGR flow requested by ECM; manifold absolute pressure (MAP) sensor - signal voltage is low.
042 - Electronic spark timing (EST) circuit - open or shorted.
I checked the following link and matched the codes to what was listed: https://www.thirdgen.org/service-eng...ht-error-codes
Any ideas what I need to do to fix these problems?
Old Apr 1, 2012 | 07:22 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: OBD Codes - What to do?
There are fault finding charts in the factory service manuals to work through.
The code only shows a fault with the system ; not that the item itself is actually faulty.
The computer say for example; expects to see a certain voltage under certain conditions.If the wire was broken or grounded then that would not happens so a code is thrown
Old Apr 7, 2012 | 12:33 PM
92GTAkid's Avatar
Engine: 305 5.0L
Ok, so I should check for faults in the circuitry before looking at the parts themselves?
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
