Smog pump delete belt question 89 tpi surpentine
Old Apr 3, 2012 | 12:47 AM
aljohnsonii's Avatar
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
Does anyone know what belt is used or the length of a surpentine belt to use to do away with the smog pump
Old Apr 3, 2012 | 09:39 AM
91'CamRS's Avatar
Car: 1991 Chevrolet Camaro RS
Engine: 305 v8 TBI
Axle/Gears: Stock
Re: Smog pump delete belt question 89 tpi surpentine
Just use a piece of string and go through the whole system like you are putting on the belt and then just measure the string and go get the correct length belt. Thats what we did for mine. (You might have to shorten the length a tad cause the tensioner will be all the way down and there wont be any tension on the string)
Old Apr 3, 2012 | 05:46 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
It's around 98.6", if you do a search for it you can find it. I personally bought the smog delete pully so I could use my factory sized belt just eliminate any confusion later on.
Old Apr 3, 2012 | 05:51 PM
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
Well it was a bunch of confusion and I finally got a belt to fix it I had tbi brakets so the belt they had listed on the tech board was to lOng so I got a 96 5/8 belt part number 6k960 and it works with out the delete pully didn't want to worry about a bearing going out in that delete pully or the pully breaking under stress
Old Apr 3, 2012 | 06:05 PM
Ozz1967's Avatar
Car: 1984 Trans Am
The delete pully's were factory options for most Canadian cars with no emissions provision, so I didn't see a worry about cracking or the bearing going out.
Old Apr 3, 2012 | 06:48 PM
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
They just don't make stuff like they use to didnt want to risk the china made stuff
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
