Aluminum Heads & EGR
Old Apr 4, 2012 | 02:55 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
Do the #10088113 heads have EGR passages? Reading on an article it looks like the ZZ4 dont have any so im wondering if used aluminum corvette have them. Thanks
Old Apr 4, 2012 | 03:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Aluminum Heads & EGR
Aluminum Corvette heads have no crossover passages.
Old Apr 4, 2012 | 04:17 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Alum head Vette TPI engines had the EGR gases supplied direct to a internal passage in the intake ( hole at rear to right and in front of dist )
from a riser tube off the pass side exh manifold
Old Apr 4, 2012 | 04:20 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
So when installed will they throw an EGR code? will they still be able to pass smog in this horrible state of cali?
Old Apr 4, 2012 | 04:26 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They could if you installed them with a complete emissions system (including the intake) from a Corvette of the same model year as your car or later and went through the referee process.
Old Apr 4, 2012 | 05:39 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Cool! Now i gotta search for the intake and all the crap that goes with it then....Thanks!
Old Apr 4, 2012 | 06:16 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Can I use the Edelbrock High-Flo intake like the picture thats posted? And if so will I need to block off the top egr port?
Old Apr 4, 2012 | 06:29 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Your EGR valve gets fitted there if you want EGR functional
The afore mentioned port at rear feeds that location ; only difference to a F-Body intake is where the Exh supply is from
midge54
Dec 27, 2019 04:14 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
bdads
Aug 24, 2015 06:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
