Intake manifold gasket
Old Apr 4, 2012 | 04:26 PM
hondorian7's Avatar
Car: 91 Chevy Camaro RS
Engine: 305 TBI
i have a 91 TBI 305 i am replacing the intake manifold gasket and when i took the old one off the back two coolant ports were blocked off. the new gasket does not have them blocked off nor does it come with the inserts to block it off. my question is do i need to keep these blocked off any info will help im still a novice thank you!!
Old Apr 4, 2012 | 04:53 PM
ex-x-fire's Avatar
Re: Intake manifold gasket
No, it can be open at all 4 corners, the gaskets that have the block off inserts are there to make coolant flow under the tbi unit & out the back heater hose connection. It just warms up the tbi unit quicker.
Old Apr 4, 2012 | 04:58 PM
hondorian7's Avatar
Engine: 305 TBI
awesome so is there any pros and cons to it or would you just put it on open?
Old Apr 4, 2012 | 06:12 PM
ex-x-fire's Avatar
If you drive it in the winter, I'd use the block off style gaskets.
Old Apr 4, 2012 | 06:15 PM
hondorian7's Avatar
Engine: 305 TBI
No winters are to rough here
Bubbajones_ya
Aug 31, 2015 12:02 PM
earlpote
Aug 28, 2015 10:42 AM
theurge
Aug 21, 2015 12:46 PM
Jake_92RS
Aug 11, 2015 10:39 AM
