What should i Use?
Old Apr 7, 2012 | 05:39 PM
GreenCamaro13's Avatar
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
What should i Use?
Ok so i bought a Intake System, but has no MAF sensor inlet, so i plan on cutting out a hole on the side to put it in.
once i cut the hole out what should i use to combine them? and how would i go about doing this? intake system looks good, here is how it looks i had to use the stock combiner since the other one didnt fix but still does the job, check it out:
This is the Old Canister that was used And the Picture under is the Sensor i will be rmoving and placing on the CAI
And here is the new one
Old Apr 7, 2012 | 07:00 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: What should i Use?
You have mentioned a MAF sensor , But pictured an IAT (Intake Air Temp) sensor . You'll need to find a place in the CAI where the IAT can see good , free airflow , and not be affected by the temp of other things in it's area (like the radiator , for instance) ....
Old Apr 7, 2012 | 07:31 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
ahh i see, i was mistaken :0. ok well do you think right next to the label on the left side if i made a whole it would fit? and how would i make it reach? because the wire is short? if i cut it, crimp it and add wire will it still work?
Old Apr 7, 2012 | 07:45 PM
OrangeBird's Avatar
Car: 1989 Firebird
I think that putting it in the area of the label will have it too close to the radiator , which will mess with it's temp readings . Notice how the radiator is right under the label ? Heat will rise up and heat up the sensor , giving it falsely higher readings . Better to put it as far forward as possible , while still having it in the incoming air flow .
Also , yea , if you properly extend the wires , you'll have no problems adding some length to the wires to get the sensor where it needs to be . Now , myself , I don't like or use crimp connections since they have the nasty habit of eventually breaking the wire they're crimped to . The good ol "Western Union" splice , soldered , and then insulated with shrink wrap or electrical tape , is the splice of choice here , and will give lasting results .
Nice looking intake , BTW .........
Old Apr 7, 2012 | 08:30 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
thankyou and ahh i see, did not think of that, where would you reccomend me to put it? pinpoint if possible?
Old Apr 7, 2012 | 08:58 PM
OrangeBird's Avatar
Car: 1989 Firebird
If it were my sender to relocate , Id do this ....
In the passenger's side of the air intake , somewhat parallel with where the wires for the headlights are . As in , Id measure back from the intake opening on the right hand (passenger"s side) of the air duct maybe about 6 or 7 inches , and put it right in the side there . Sort of adjacent to where it looks like there is some hold down hardware for the duct .
I'm sorry I'm not that computer savvy to take a photo and highlight an area (old guy retired mechanic here , spent my time with machines and not computers ) , But I hope my description helped ?
Old Apr 7, 2012 | 08:59 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
will it work there? like will it get same readings like it should?
Old Apr 7, 2012 | 09:13 PM
OrangeBird's Avatar
Car: 1989 Firebird
All it needs to be is in the airflow of the incoming air , and in a place where it wont be affected by warm things (like the radiator) and it will do fine . As it was when it was in the original can filter , it can just as easily be in the CAI duct , and now you have a good idea of where to install it .
Of course , you'll come in from the side , and not the top or bottom of the CAI duct , facing inwards from the passenger's side . Do the wire extensions with wire of the same thickness as the existing wire , and it'll be fine .
Just be sure you make the right hole size to thread the sensor into . "sneak up on it" by gradually making the hole larger , trying the sender till ya get close enough to thread it into the plastic . A small bead of any decent brand of RTV silicone around the threads will hold it in place , and that will do it .
