87 Iroc bad stalling issues, almost got me killed.
Car: 1987 IROC Z28 Camaro
Engine: HSR L98
Axle/Gears: stock
My 87 Iroc with a 5.7 continues to stall repeatedly.
I replaced the MAF, TPS, adjusted the injections, new fuel pump.
The process goes like this. I crank the car and it runs fine for about 5 or so minutes. Then it idles down to about 800RPM..and a few minutes more it will just stall.
And when it idles down to around 800 and I put it into reverse or drive, it will stall out.
I have to get this thing inspected soon so if anyone can help it will be really appreciated :/.
And about the death thing. I was at an intersection turning right on red, car was coming but I knew I could make it, let off brake and started to roll then it just stalls on me, so I go rolling right out in front of the car.
I WILL POST A VIDEO SOON
Re: 87 Iroc bad stalling issues, almost got me killed.
adjusted the injections?
Instead of slapping on new parts, verify a couple things first
What is the minimum air setting? idle speed w/ iac closed? Timing set correctly? Do those first then see if it still stalls. If it does, check the grams per second that the maf reads.
Engine: 4++,350 & 305 CIs
Is the tank full ? Whats the fuel PSI? How old is the pickup coil and ICM? When was its last tuneup? How old is the Fuel filter? How many miles are on it? Do yo have a factory service manual?
Engine: HSR L98
Axle/Gears: stock
My father is gone for the week (he's the veteran mechanic) and Im taking things slow.
I know the timing is set correctly
Thanks for the reply!
Engine: HSR L98
Axle/Gears: stock
not sure on PSI
ICM is a few months old.
Last tuneup a year ago
Filter is less than a year
41,000 original miles.
And I ordered a manual and its on the way.
Engine: HSR L98
Axle/Gears: stock
Haven't got to try anything buy I borrowed a Diagnostic tool and will hook it up to see if it throws me anything.
High school kid keyed my hood and I've been having to deal with that...
What a horrible past couple weeks
Car: 87 z28 stock
Engine: 305 tpi
mustangman65_79
Aug 11, 2015 03:17 PM
