need to know what sensors these are
Old Apr 8, 2012 | 10:58 PM
KuroNeko's Avatar
Car: 1986 Firebird, 1992 camaro
Engine: 79' 350, 89 305
Transmission: TH400, 700r4
so anyways, i have an 86 firebird with the code for LG4 but the engine was swapped to an 84 so as of right now its still a mystery if its L69 or just lg4, but anyways, i have found that the car has two sensors that look like map sensors..... if they are why do i have them? i thought those were only for FI engines? if they arnt and i acctually need them, then what are they? i have to rewire the plug for one since it looks like a mouse got to it
(the one on the right)
Old Apr 9, 2012 | 12:38 AM
NullHead's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
Axle/Gears: 3.73, Detroit Trutrac, 10 bolt
Re: need to know what sensors these are
Looks like a MAP sensor and harness to me. Perhaps it was fuel injected at one point? Otherwise, you really don't need a MAP if it's carbureted. The only other use would be for an electronically shifted transmission, but that seems unlikely.
Old Apr 9, 2012 | 01:25 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by NullHead
. The only other use would be for an electronically shifted transmission,.
No electronic shifting back in those days ;
Old Apr 9, 2012 | 03:09 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
That is a MAP sensor, they were used computer controlled carbs.
Old Apr 9, 2012 | 11:03 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
BARO sensor, not MAP
Old Apr 9, 2012 | 11:21 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Baro sensor would be on the opposite (right) side. Left side by booster would be the VAC sensor (as opposed to FI's MAP).
If you no longer have the computer controlled carburetor and distributor, you can leave them alone.
Old Apr 9, 2012 | 06:11 PM
KuroNeko's Avatar
and if i didnt say it before, there are 2 of these sensors, one is on the left attached on the lip right above the ac stuff and the carb is a quadrajet that has plugs so i think it might be electronically controlled
Old Apr 10, 2012 | 08:07 AM
naf's Avatar
naf
Not anymore.
If the MCS inside the carb is clicking when the key is turned to 'run' you may not be far away from getting it back the way it should be.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
