Vortec swap- cam questions
Old Apr 9, 2012 | 01:29 PM
USMCBeck's Avatar
Well I am planning on swapping out my heads for vortec heads. I have a roller sbc 355. Right now it has a GM ZZ2 cam the lift is 480, and I was wondering if anyone used this cam with vortec heads #906 and if I would be better off swapping the cam as well?
Any comments would be much appreciated.
My goal is to make around 400-450 Hp at the flywheel eventually.
I already have the heads and a vortec intake.
Old Apr 9, 2012 | 01:33 PM
conlinj's Avatar
Re: Vortec swap- cam questions
are the heads stock? or will you have them clearanced for higher lift cams?
Old Apr 9, 2012 | 01:40 PM
USMCBeck's Avatar
Stock right now, But I could have them machined. Or use a thicker gasket?
I'm just curious how well the ZZ Cam would work on the Vortec heads. If I swap the cam, I'm unsure what I would go to.
Old Apr 9, 2012 | 02:16 PM
conlinj's Avatar
what are the rest of the specs on the cam? .450+/- is around the max lift for stock vortec heads. You would really have to check your clearances to run the zz2 cam you have now. The safest bet is to have them machined for higher lift and go from there. Stock vortecs only flow well to @500 lift. I wouldn't recommend running a cam with a lift higher than .550 with the vortecs unless you plan on going with better heads in the long run.
Old Apr 9, 2012 | 02:21 PM
USMCBeck's Avatar
The duration at lash point in degrees (intake/exhaust) is 336/336; duration at .050" tappet lift (intake/exhaust) is 235/235; and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 480/480. Valve lash is zero/zero and lobe centerline is 114 degrees.
Old Apr 9, 2012 | 02:56 PM
conlinj's Avatar
Not a bad cam, wouldn't be worth the swap to anything with similar specs. You can try it with the heads in stock form and go over the clearances, odds are you will have to have them machined though. After they are machined you could consider swapping to a cam with more lift and a lower centerline. Another option would be to keep the cam and go with 1.6 rockers. That would bring you to .512 lift
Old Apr 9, 2012 | 03:10 PM
USMCBeck's Avatar
1.6 self aligning roller rocks would require screw in studs right? So If I used 1.6 rockers how would that help me compared to 1.5s? Would it just help with clearance issues?
Old Apr 9, 2012 | 03:18 PM
conlinj's Avatar
1.6 rockers effectively make your cam larger than it is, it would make the clearance issues worse if you don't have the heads machined.
Old Apr 9, 2012 | 03:23 PM
USMCBeck's Avatar
Well I guess Depending on clearance, My best would be to machine them and get 1.6 rockers then, because i need rockers that are self aligning anyways. Thanks for the info.
Old Apr 9, 2012 | 03:26 PM
USMCBeck's Avatar
What springs would be good for my heads, because I'm guessing the stock ones might cause my valves to float.
Old Apr 9, 2012 | 03:36 PM
conlinj's Avatar
talk to the machine shop that will be doing the heads, they should be able to give you advice on the springs
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
