Broke exhaust stud drilled to far now water coming out help
Old Apr 10, 2012 | 12:18 AM
aljohnsonii's Avatar
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
I broke a bolt off in my head and I tried to drill it out and extract it and I went little to far and now water is coming out is this a problem and should replace head or is it normal for water to come out of certain head holes like that what way should I fix it bolt is still in head
305 ho tpi with headers
Old Apr 10, 2012 | 12:32 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Broke exhaust stud drilled to far now water coming out help
Thread sealer on the new bolt might take care of it.
Old Apr 10, 2012 | 12:35 AM
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
Can't get bolt out thinkin bout swap motor
Old Apr 10, 2012 | 07:38 AM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
did you salvage the threads or did you have to retap it?
maybe get a small hex key plug slather it in JB weld and run it all the way to the bottom of the hole and use a slightly shorter bolt.
eightsixseven
Dec 16, 2024 01:50 PM
transaero
Aug 31, 2015 01:14 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
Dialed_In
Aug 20, 2015 01:45 PM
