Will it fit (LT1 gas tank)
Old Apr 10, 2012 | 01:16 AM
thunder57's Avatar
Car: 1987 IROC
Axle/Gears: 3:42, 10 Bolt LT1
I am in the process of swapping over an LT1/T56 from a 97 donor car into a TBI 89 Camaro. I pulled both gas tanks and I found the fourth gen unit is in much better condition, and it appears the third gen one was leaking from the sending unit. Originally I was going to sell the LT1 fuel tank and put in a AC Delco EP381 unit into the third gen tank.
Based on these pictures, the dirty tank is the third gen, is there any reason why I wouldn't be able to use the fourth gen unit? Would I be able to use my new pump if I did run it? Thanks.
Attached Thumbnails Will it fit (LT1 gas tank)-1.jpg   Will it fit (LT1 gas tank)-2.jpg   Will it fit (LT1 gas tank)-3.jpg
Old Apr 10, 2012 | 12:58 PM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Re: Will it fit (LT1 gas tank)
Whip your measuring stick out and get the height, width and any other 'contact' points... if they are roughly the same, then i'd say yes it would work
Old Dec 5, 2013 | 12:28 AM
asm383's Avatar
Car: 91 z28 convertible
Engine: 350lt1
so did it work?
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
