Obd1 codes
Old Apr 10, 2012 | 11:53 PM
pvr007's Avatar
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
Obd1 codes
15-engine coolent temp
23-intAke air temp sensor
32-egr system failure
43-knock sensor
44-oxygen sensor error
54-digital egr valve selenoid 2 error
Or 54 could be fuel pump circuit(low voltage
These are all the codes i got on my 88 camaro rs 5.0 tbi 5 speed stick
I know the sensor pigtail has to be replaced
Egr might be beause i habent hooked up the t with the air pump and i connected it directly to the tbi
Knock sensor is missing that i know
Oxygen sensor says its lean? Wtf
54 might be same as 32
Old Apr 11, 2012 | 12:16 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Obd1 codes
Originally Posted by pvr007
15-engine coolent temp I know the sensor pigtail has to be replaced
Until you fix the obvious faults , little point looking at the codes because a fault say with the CTS can give problems with other things
The sensors were installed by GM for a reason ; to make the engine run PROPERLY !
Old Apr 11, 2012 | 02:24 AM
pvr007's Avatar
Engine: 305 TBI
Re: Obd1 codes
Well tomarrow ill try to rewire the egr and some connectors
Old Apr 11, 2012 | 03:32 AM
pvr007's Avatar
Engine: 305 TBI
Re: Obd1 codes
also its not like i took the sensors off... it was the Previous owner
Old Apr 11, 2012 | 03:34 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: Obd1 codes
Forget the EGR
Engine will run happy with no EGR ;it only throws a code.
CTS is the most important sensor for engine operation then O2 then knock sensor
If the other sensors( or wiring ) are faulty then you will have problems
Old Apr 11, 2012 | 04:27 AM
pvr007's Avatar
Engine: 305 TBI
Re: Obd1 codes
CTS= Coolent Tempeture Sensor?
the fan doesnt come on unless i turn on the AC and i always run it with the Ac/FAN on.... might that be an issue?
Old May 12, 2012 | 01:59 AM
pvr007's Avatar
Engine: 305 TBI
Re: Obd1 codes
soo after a new battery i only had code 15... fixed code 15... CEL wont come up untill operating temp... now i get 32 43 44.... i replaced knoking but the pig tail was borken so im going to replace it... also o2 sensor will be replaced.. and 32... guess i need a new EGR
Old May 12, 2012 | 10:04 AM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Re: Obd1 codes
So a new battery made all our codes but 15 dissapear? Doesnt make sense to me..
If the pigtail is broken that would explain the code for the knock sensor
Check the diaphram on the egr first, while its running make sure you feel the diaphram moving
Old May 12, 2012 | 10:10 AM
pvr007's Avatar
Engine: 305 TBI
Re: Obd1 codes
how do i do that
Old May 13, 2012 | 09:51 PM
Black88Z's Avatar
Re: Obd1 codes
lol. just put your hand under the egr while the cars running and try to tell if you feel the diaphram moving. Also, while its off, push on it a little bit. It should be very easy to move, if it gives resistance it probably needs to be replaced
It could also be your egr temp sensor, to be sure i looked it up and it says code 32 is Fault in exhaust gas recirculation valve diagnostic switch, hence the DIAGNOSTIC SWITCH. Your EGR may be ok, its possible the temperature sensor for it is the problem.
Either way, check the EGR diaphram first then go from there
Old May 14, 2012 | 01:27 AM
pvr007's Avatar
Engine: 305 TBI
Re: Obd1 codes
well i ordered the ALDL cable... should get home around Wednesday.. i had code 15... fixed that by replacing pig tail and CTS... not i get 32 43 44... but i only get it when i go over 50 mph... while cruising code doesnt show up... also when i turn off the car the code disappears
i already got a new knoking sensor... unless i put it in the wrong hole... or the connector was broken
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
