Clamshell motor brackets!
Old Apr 11, 2012 | 02:52 PM
mr z28's Avatar
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
I have a 87 iroc an just put a set of poly motor mounts in the drivers side fits good but the pass. side tabs on the mounts dont seen to fit the grooves in the clamshell. Could I use the same mount thats on the drivers side on the pass. side or will there be a problem? Will this lower the motor on one side? Or will I be ok .Any suggestions will be a big help to me. Thank you. 350 motor.
Old Apr 16, 2012 | 07:51 AM
steeljab's Avatar
Car: 87' Camaro
Engine: 305 carbed
Re: Clamshell motor brackets!
check, check, and check again to make sure you have the correct mounts and flips/rotated/facing the correct way. i remember having that same problem and realizing i had them swapped and facing the wrong ways, driver side worked, pass side didn't
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
Genopsyde
Nov 11, 2015 10:46 PM
NBrehm
Aug 5, 2015 07:57 PM
