Head porting books?
Car: 91z
Engine: 350 vortec
Transmission: built 700r4
Axle/Gears: 373
Head porting books?
As the title says, do any of you know of a well detailed book on how to port vortec heads? I thought David Vizard had one?! If he did, what book of his did he have the write up in? thanks guys!
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Re: Head porting books?
Yeah he wrote a book in '99 about building SBCs on a budget. I've got it somewhere around here. He talks about porting heads in it and does talk about vortecs. Although I recall that he concluded there was little to gain because they flow pretty well in stock form.
As a side note his books rock!
This is the one it's in:
http://www.amazon.com/Build-Performa...274106&sr=1-14
What we found out for yrs and yrs and yrs,we have got it wrong with the free-hand die grinders.That the only true way to be sure each port is matched is threw a programed 5 position CNC porting.And we also found what makes Vortec's is the rough surface.
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
its 5 Axis CNC porting and most here are young first time 3rd gen owners that cant afford automated CNC porting at a shop so they learn to do it themselves.
Car: 91z
Engine: 350 vortec
Axle/Gears: 373
All true...There is a thread about 50pages long where some guys have had great success porting the vortecs. If you type in "Dirt Reynolds vortec" under google you can find it. I believe its Nastyz28.com. Lots of good info there just no pics or details. I wish there was someone closer to me that knew how to port them properly with a flowbench. I would love to learn how
.We did a heat probe test on each exhaust port and found more than 25% difference port to port that was done by a expert porter.And again,what makes Vortec's special and work like they do is the rough intake port.Smoother exhaust ports on the other hand did show improvements. Thread
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
Dialed_In
Aug 20, 2015 01:45 PM
