Ticking coming from behind radio/under shifter
Old Apr 12, 2012 | 06:46 PM
RWO3's Avatar
Car: '84 Camaro Sport Coupe
Engine: 355
Axle/Gears: 3.08
I've been hearing a ticking noise coming from behind the radio/under the shifter console. (I know it has nothing to do with the radio) The noise will happen randomly as I'm driving and can last from 10 seconds to minutes. The noise will go away when I slow down under 25 mph but not if I shift into neutral. The noise rarely happens when idling, usually when I'm driving. The sound is a fast clicking that fades back and forth from louder to softer.
One time, I heard the noise and shifted into neutral but it was still there, so I reved the engine while coasting and the ticking got faster with the rpms, not my speed.
I don't know what in the world this could be... Any ideas?
Thanks.
Old Apr 12, 2012 | 07:10 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Ticking coming from behind radio/under shifter
OK you have an automatic so you need to get under your car a take off the inspection cover between your trans. and motor, get a good light and look around in there. Maybe a bolt is coming loose on the torque converter or something look around and let us know. Remember not to trust the jack you need to use jack stands also.
Old Nov 10, 2012 | 07:49 PM
drjewalton's Avatar
Car: 1956 Chevrolet 210
Engine: Chevy 305 V8
Transmission: TH350
Axle/Gears: Posi 3.42
Thanks.
I too have the EXACT same issue...I too have a 1984 Z28 but mine is a 5 speed.
No change in performance, just irritating. Sound occurs just like mentioned above, sometimes a few seconds, other times for several minutes - then disappears.
Fades louder to softer and goes faster with RPM's, even if I coast in neutral and rev.
In the recent past, I have had to replace the pick up coil in the distributor. Also replaced the rotor and Ignition control module.
Could the aftermarket pick up coil cause this? My question is this: Why intermittant? What would make this sound just occur OCCASIONALLY?
Any thoughts or suggestions appreciated -- hopefully someone on this forum has experienced and SOLVED this mystery!
Old Nov 24, 2013 | 01:14 PM
drjewalton's Avatar
Transmission: TH350
SOLVED! The culprit: Mechanical Fuel Pump. Replaced with new Carter fuel pump and new push rod....all ticks are gone!
BewleyBizzIROC
Feb 3, 2020 09:52 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
db057
Sep 4, 2015 07:57 AM
NBrehm
Aug 25, 2015 11:49 PM
redmaroz
Aug 16, 2015 11:40 PM
