coolant temp sensor
Old Apr 19, 2012 | 07:29 AM
ethan169's Avatar
coolant temp sensor
I have an 87 formula with 305 and 5speed. From what I can gather the 5 speed it has is a T5? And the 305 is well im not sure....
Car has been sitting for quite a few years but driven or at least started every once in a while just because. My temp gauge is not working currently and there is a sensor that is not plugged in because one of the prongs broke off. It looks to be original so im not surprised. I believe it is on the inlet to the water pump. Its a little screw in type. What is this and where can I get a new one from? Autozone and those stores dont seem to have a coolant temp sensor or anything like that. And those guys are clueless about looking up things in a book.
I am 90% sure this is why my temp gauge is not working. Am I right in thinking this? Or close anyway?
Thanks for any help.
Ethan
Old Apr 19, 2012 | 10:59 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: coolant temp sensor
The 5 speed is a T5, the 305 is a small block chevy.
The temperature gauge sender is in the driver side head between the #1 and #3 cylinders. The temperature sensor for the computer is on the waterneck.
Old Apr 19, 2012 | 11:52 AM
ethan169's Avatar
Thanks for your response.
Im not sure my computer is doing much right now as I have the HEI coil in cap w/ vacuum advance distributor (not sure if its the right one or if that matters, it is from a small block chevy though) and a edelbrock manual secondary carb. So this sensor is most likely not needed? Am I correct in assuming this?
The gauge on the cluster for temp...I would assume that it takes its signal from the sender on the side of the block? Maybe I can check the connection there. There are so many sensors and harnesses unplugged its hard to tell what is going on.
Thanks again
Old Apr 19, 2012 | 12:53 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Coolant temperature sensor isn't needed if the computer isn't functional.
The gauge sender is in the head, not the block.
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
L98GTA87
Oct 19, 2015 10:43 PM
corey8084
Sep 17, 2015 02:56 PM
m00n420
Sep 11, 2015 02:39 PM
