Bad vacuum advance?
Old Apr 19, 2012 | 09:39 PM
JLCustomizing's Avatar
Car: 1984 Trans Am
Engine: 5.7 Liter V8
Transmission: Auto 700R4
Axle/Gears: Stock
Bad vacuum advance?
So sometimes my car is running great, other times at WOT it stumbles or has rough idle. Ive had the carb rebuilt, the engines only got 2000 miles on it (performance build). Is it possible since its still the gm HEI distributor that the vacuum advance could be sticking after all these years? Shop keeps timing the engine to try to get it right but it only lasts for so long before it goes back to bogging etc.
(84 trans am)
Old Apr 20, 2012 | 06:31 PM
ex-x-fire's Avatar
Re: Bad vacuum advance?
Is it a stock distributor? They were only computer controlled.
Old Apr 20, 2012 | 07:20 PM
Damon's Avatar
Since you list a 350 as your engine I'm guessing it's not stock and doesn't have computer controls any more?
If it's got a vacuum advance distributor you can test it. Just apply vacuum to the hose fitting on the vacuum advance canister while you watch the timing advance with your timing gun. If you have a hand vacuum pump with a gage on it, that's even better. Most cans start to supply advance around 3" of vacuum and top out around 9-10" of vacuum. It should NOT leak vacuum (ruptured diaphragm) and it should move smoothly through the advance curve as you apply more vacuum, snapping back to full retard the instant vacuum is removed.
A typical stock can will supply a maximum of about 20* of advance between the full-retard and full-advance limits.
db057
Sep 4, 2015 07:57 AM
Glowsock
Aug 31, 2015 09:01 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
86IROC112
Aug 17, 2015 02:00 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
