oil pump question
Old Apr 22, 2012 | 01:14 PM
hondorian7's Avatar
Car: 91 Chevy Camaro RS
Engine: 305 TBI
oil pump question
just to make sure im correct the difference between some high volume oil pumps (not a big expensive one) compared to the stock can be just the amount that it lets bypass correct? cause the new one i got looks exactly the same as the stock.
Old Apr 22, 2012 | 01:30 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Re: oil pump question
If you have a high volume pump the pump body should be taller because the gear is bigger. That's what produces the higher volume. If the pump size is the same, you might want to make sure you didn't get a high pressure oil pump, which has a different spring that raise the oil pressure from the stock 55-60 psi to a much higher reading in the 70-80 psi range.
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
92camaroJoe
Aug 13, 2015 06:07 AM
