engine problem
Old Apr 15, 2012 | 02:43 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
engine problem
Ok first gear hammer down shift at 5k, hard thru 2nd gear hit 4500 (about 80mph) engine just stalls for quick sec then misses and jerks around, shift into 3rd same thing at about 80mph. Ive tried 3 carbs small medium large, replaced plugs distributor brand new and tried 3 sets of blue max plug wires. Check valves repeatedly, this last time i hooked up vac advance set timing to total 34 degrees, 2nd gear couldnt get past 3800rpm. Im stumped, anyone got any ideas? Thanks for your time.
Old Apr 15, 2012 | 03:52 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: engine problem
If it was my car I would be looking at the valve springs and push rods.
Old Apr 15, 2012 | 04:41 PM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
Re: engine problem
What would be wrong with the pushrods?
Old Apr 15, 2012 | 04:48 PM
Edwardgp's Avatar
Engine: 454-350
Re: engine problem
I would just check them out to make sure they are not bent, I was thinking the way it is acting that it might be an issue with the lifters, push rods, or valve springs.
Old Apr 15, 2012 | 04:53 PM
mjwadams's Avatar
Car: 92 RS
Engine: L03 with Holley Sniper EFI, headers
Transmission: T-5, hurst billet shifter
Axle/Gears: 3.08 posi
Re: engine problem
I would tend to agree with Edwardgp. The pushrods have a lot of reciprocating mass which effectively limits RPM. That is why OHC engines usually have higher red-lines than OHV ones. Your valve springs are what controls this mass and keeps the valves from hitting the pistons. If they are worn, it can affect the timing, more so at high RPM. You can also grenade the motor, same as if the timing belt breaks on an OHC motor.
I would keep it below 3K until you checkout the valve train.
Old Apr 15, 2012 | 05:06 PM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
Re: engine problem
Ok ill check it out. Thanks for the tips.
Old Apr 17, 2012 | 09:20 PM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
Re: engine problem
Fuel pump is bad.
Old Apr 18, 2012 | 06:40 AM
Edwardgp's Avatar
Engine: 454-350
Re: engine problem
Let us know if that fixes it for you.
Old Apr 22, 2012 | 09:38 PM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
Re: engine problem
It is confirmed, mechanical fuel was bad, engine runs awesome now.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
