Compression Ratio
Old Apr 24, 2012 | 02:01 PM
83DTA's Avatar
Car: 1983 Daytona Trans am
Compression Ratio
hello, i just need some help with some compression ratio things here. i just picked up a very cheap set of "336x" heads and i am right now port matching and just cleaning up casting slag and smoothing them. im not going crazy on them i just want them to match and be a bit better flowing. now to my qusetion. they are 76 cc heads and i was going to polish the combustion chambers, just to make them smooth and no places to cause pre-detenation. i can not find out what my compress ratio will be. i do not know what cc'c will be gone out of the head's by knocking down the rough casting. just wonder if somebody could give me some input on that. specs below.
- 350 v8
- 4.001 bore and 3.48 stroke
- 76 cc heads (maybe 78 after polishing?)
- +5 cc dome pistons 4 valve reliefs
- no machine work
what size shim head gasket will be needed and i do not know how far the piston is down in the bore but i am guessing it is stock. i want as high compression ratio as i can get (wont be that high i dont think deffently under 10-1) with out machine work. maybe even if somebody could give me a formula i could do it on my own.
Old Apr 24, 2012 | 02:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Compression Ratio
About 9:1 if you're lucky.
Old Apr 24, 2012 | 02:14 PM
83DTA's Avatar
What size head gasket would that be with?
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
