Oil Leak causing idle issue??
Old Apr 24, 2012 | 08:55 PM
ZeBatmobile's Avatar
Car: 92 Z28
Engine: 350 (ZZ4 Block) '193 heads.
Transmission: WC T-5
Axle/Gears: 3.42 Posi
Hello, I am back!! I have begun to DIY prom again with my ostrich 2.0. I got the SA table DIALED in. Other little tables/constants modded blah blah blah. The reason for this thread is to ask:
If the end seal on the intake manifold was not properly applied (RTV silicone orange), could this cause a vacuum leak via the PCV system?? It seems reasonable to me.
I am pretty sure it is leaking from there, about a Kennedy half dollar size every time i park. I replaced the stock intake manifold with an Edelbrock TPI and runners about 3 years ago and may have (did) half arsed it.
Vehicle is a 1992 camaro 350 tpi
Old Apr 25, 2012 | 05:31 AM
Re: Oil Leak causing idle issue??
Not likely. It would just act as a tiny source of make-up air, replacing a tiny amount of what otherwise comes in from in front of the TB.
specialized
Jun 18, 2022 09:26 AM
Fronzizzle
Mar 18, 2019 08:29 PM
Navy8125
Aug 21, 2015 09:32 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
drathaar907
Aug 6, 2015 04:20 PM
