Jumper cable question.
Old Apr 25, 2012 | 03:01 PM
Elthesh's Avatar
Car: 1991 Pontiac Trans Am
I could'nt really find an answer for this but a friend and I were pondering if you can use jumper cables without a battery in one of the vehicles. Meaning, run the cables from your running car with a battery directly to the cables in the batteryless car. Say if you needed to close a window, power a trunk or whatever.
Old Apr 25, 2012 | 03:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Jumper cable question.
Yes
Old Apr 25, 2012 | 03:05 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Sure you can. But if it is say.....A junkyard car.....There could be bare wires power laying somewhere touching ground causing a short circuit.
Old Apr 25, 2012 | 06:33 PM
Elthesh's Avatar
Thanks for the info. Also, yes, a junkyard card would be a bad idea to do that on. That you'd definately want to use a car battery with. Better to lose a battery then fry your working car's system.
Old Apr 25, 2012 | 06:58 PM
Car: GTA
If it was just a car with a dead battery that you lost the keys to but had remote lock/unlock doors, that would work IF you could get to the battery cables with the doors closed & no external hood latch like the early cars had, unlike the 3rd gens do. I have seriously considered adding an external hood release for that very reason.
$750 L98
Feb 1, 2025 02:25 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
