size fittings on fuel line??????
Old Apr 27, 2012 | 04:42 PM
bad to be blown's Avatar
Car: 89 gta
Engine: 5.7 supercharged
hi guys just buying the stuff i need for my new fuel line set up. the old lines are rusty and on there ways out and im putting a in line pump to.
can any one tell me what thread the main fittings are to the fuel rail from the fuel line???
would be a great help
thanks
bad
Old Apr 27, 2012 | 07:09 PM
82_Camaro's Avatar
Car: 82 Z28
Transmission: Turbo 200C
Axle/Gears: 3.43
Re: size fittings on fuel line??????
should be 3/8 i would assume. are you going to put a hardline back in or are you going to do a steel braided line?
Old Apr 27, 2012 | 07:31 PM
Car: 89 gta
full braided line from front to back of the car, with the new fuel pump around the half way mark
Old Apr 28, 2012 | 05:32 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
They are metric Saginaw fittings:
14mm x 1.50" to -6: "O" Ring Seal, return
16mm x 1.50" to -6: "O" Ring Seal, feed
Moving to General Tech...
RBob.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
