NEWBY NEEDS HELP
NEWBY NEEDS HELP
I RECENTLY BOUGHT A PROJECT CAR FOR MY 11YRER OLD AND I TO WORK ON TOGETHER...1984 Z28 5.0 4BBL H.O. ,5 SPD MANUAL,L69 ..CAR IS ALL ORIGINAL..78000 ON ODOMETER..THE CAR NEEDS SOME LOVE BUT EVERYTHING IS THERE..OK I STARTED OFF WITH SUSPENSIOIN SPRINGS,SHOCKS ,BALL JOINT ,TIE RODS ,DRAG LINK,SWAY BAR ..DONE, THE CAR RUNS BUT MY QUESTION TO YOU GUYS ... DO I REPLACE ALL ORIGINAL EMISSION AND VACUUEM LINES OR TEAR OUT EVERYTHING ? REPLACING ALL THE CRACKED VAC LINES AND EMISSSION CONTROL STUFF LOOKS INVOLVED AND ARE THOSE PARTS AVAILABLE?
Re: NEWBY NEEDS HELP
Your post is almost impossible to read.
I'll give you the benefit of the doubt ONCE though, this being your first post.
Vacuum line, including the thin plastic kind and the rubber ends for it, are available at ANY parts store, even AZ and Advance and the like. Not much of a challenge if the car needs them.
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
LOL! i love it haha ^.
Here is my two cents, test everything, and if it needs replaceing replace, if not use those cents on something else that does need replacement. get it in top shape with good plugs and wires so that it starts and the pitch of the crank.
rubblerubble
Mar 13, 2016 06:57 PM
