Metal in oil, slight knock, and vibration - engine is toast, but what happened?
Old May 9, 2012 | 05:57 PM
mike_c's Avatar
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
Here's what's going on:
-There's a lot of metal in the oil.
-There's a slight knock
-I can feel a vibration through the shifter
I just put a T56 in it maybe 700 miles ago. Not sure if that's related or not. LT1's and L98's are both internally balanced, so using an LT1 flywheel shouldn't have thrown the engine balance off. It's also leaking at the rear main seal. It's been a bit damp back there for a year or two, but never bad enough to drip on the ground. Now it is. I don't know if this is a coincidence or not. The engine also has 104k on it. Any ideas what caused this?
Here's some pics of the oil I just drained out:
Old May 9, 2012 | 06:12 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Metal in oil, slight knock, and vibration - engine is toast, but what happened?
Wooooo. Bearing material swirls in the oil is really bad news.
Old May 9, 2012 | 06:20 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
time to pull it out for a rebuild..tough to say what the
cause was:water in the oil,high revs with cold oil,
grooved journals,are just a few possible causes...
just have to fix it up better than it was before
Old May 10, 2012 | 04:42 PM
mike_c's Avatar
I think I figured out what happened. I took a peek in the radiator last night and the coolant was clean, but the level itself was pretty low. Coolant got into the oil and this is the result.
Old May 10, 2012 | 09:05 PM
85gulstrandTA's Avatar
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
looks like you caught it early, looks more like a milk shake and more brownish in color when it's really bad.
italiano67
Dec 11, 2016 09:21 AM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
gwade12
Aug 8, 2015 08:17 AM
