oil change at speed lube left me with no oil help
Old May 10, 2012 | 12:34 PM
jaybdaboat's Avatar
Car: 1987 Sports coupe/z28
Engine: 2.8/ swapping 5.3
Axle/Gears: Open 3.42
I took my 350 tbi to get an oil change at speed lube before work.
Watched them put in oil because I lost an firebird to them forgetting.
Drive home, turn the car off oil guage says 60. Cut it on drive 8 miles to work,
Car started smoking thought maybe they spilled oil on the engine.
Get to work, check the oil its empty. Get them to look at it, and it's leaking
By the oil filter, squirting out when the engine is on. He thinks its a missing sensor
Any ideas before they look at it in the morning?
Old May 10, 2012 | 12:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: oil change at speed lube left me with no oil help
Looking at it would be the first step.
Old May 10, 2012 | 12:40 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Most cars don't have a sensor near the oil filter. Most likely, the rubber gasket from the old oil filter stuck to your block, so now it's double-gasketed, which leaks like hell.
When they pull the filter off the car, stand there and watch it very carefully to make sure they don't "hide" the 2nd gasket as they take things apart, if that is in fact the problem.
Old May 10, 2012 | 12:48 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
This is why I change my own oil!
Old May 10, 2012 | 01:00 PM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
I've also had a seal on the oil filter warp as I put it on... Inspect the oil filter as well
Old May 10, 2012 | 04:15 PM
jaybdaboat's Avatar
Some reason I accidentally posted two threads but the others are saying the same.
eightsixseven
Dec 16, 2024 01:50 PM
Navy8125
Aug 21, 2015 09:32 AM
kyleb24
Aug 15, 2015 08:24 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
