RPM fluctuation
Old May 12, 2012 | 03:23 PM
NoWayKemosabe's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
Transmission: Automatic
RPM fluctuation
I have a 1989 2.8L V6 Automatic Camaro RS and the rpms keep dropping randomly. The check engine light is on but i don't have a code checker to use. It used to only happen after driving for like ten minutes but now it does it from the start of driving. I can be accelerating, decelerating, or nothing and they still drop like crazy. Any suggestions on what it might be?
Old May 12, 2012 | 05:32 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: RPM fluctuation
Is the motor itself dropping off or just the tach showing low? If the motor isn't dropping off, its probably a tach error. I know the tach is a major issue in the 90-92 cars and could be in an 89 also.
Old May 12, 2012 | 05:54 PM
Car: 1989 Camaro RS
Engine: 2.8L V6
Re: RPM fluctuation
It's not just the tach. For instance, when I accelerate after a stop or something it feels like the motor lags almost.
Old May 12, 2012 | 09:24 PM
jtsk's Avatar
Re: RPM fluctuation
hmmm, interesting. Fuel filter perhaps. Has it had a tune up lately?
Old May 12, 2012 | 09:26 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Re: RPM fluctuation
Has it progressively gotten worse? Could be the timing chain or a fuel problem.
Old May 12, 2012 | 09:29 PM
spdhawk77's Avatar
Car: 89 Formula
Engine: 305 T.B.I.
Transmission: 5 Speed Manual
Re: RPM fluctuation
you can use a jumper wire on the diagnostic plug under steering wheel to get the codes. I'd start there. Definitely could be fuel pressure related or electrical, a code could help narrow it down.
Old May 13, 2012 | 01:30 PM
Car: 1989 Camaro RS
Engine: 2.8L V6
Re: RPM fluctuation
No, I haven't had a tune up lately. It kind of has gotten worse. Before it happened after 10 minutes of driving and the rpms dropped really hard and fast but now it starts when i turn the car on and it drops only slightly now, not so hard and fast as before.
Old May 13, 2012 | 04:15 PM
jtsk's Avatar
Re: RPM fluctuation
how many miles on the car?
Old May 13, 2012 | 04:25 PM
Car: 1989 Camaro RS
Engine: 2.8L V6
Re: RPM fluctuation
181,000 total miles
Old May 13, 2012 | 04:38 PM
jtsk's Avatar
Re: RPM fluctuation
Could be due for a new distributor. I had to replace mine in my z28 at 141k. It was "chugging" off and on. I am wondering if that might be similar to what you are experiencing.
Old May 13, 2012 | 04:51 PM
pima.1971's Avatar
Re: RPM fluctuation
o2 sensor getting worse making it run real rich? Just a thought.
db057
Jan 10, 2020 08:55 PM
Elephantismo
Feb 13, 2019 12:51 AM
ULTM8Z
Oct 2, 2015 01:25 PM
Damon
Sep 26, 2015 04:29 PM
