Pistons, cam, heads, crankshaft, what kind of power?
Old May 13, 2012 | 10:50 PM
Guest
Guest
Posts: n/a
A guy I met at an after school activity liked my car and offered to give me some free parts. I do not know the brand or dimensions or any specifics at all, but he is giving me a camshaft, crankshaft, flat head pistons, heads, and rods. I'm not stupid so I know with this minute amount of information you guys can't tell me hardly anything, but what kind of power gains will that give me. Just major ballparking. I know most that stuff will give alot of power in conjunction with other mods. I am planning on boosting eventually so I believe these will really help in that area. I currently have full three inch exhaust and headers as my only mods. Just want to know what kind of power I could see out of these new parts alone added to my current set up.
Old May 14, 2012 | 02:29 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: Pistons, cam, heads, crankshaft, what kind of power?
Crankshaft, if 350 will not give a power gain but may be stronger. Is it 1 pc rr main or older 2 pc rr main seal crankshaft?
Cam see if ther is any info on it, name or numbers. Too many cams to guess.
Heads, give us the number that is cast on them under the valve cover.
Rods, no power gains but may be stronger. Get a picture or try to find numbers and a very good description.
Flat top pistons will increase compression ratio and increase power but what is the head cc. Overall increase in power would be determined by the cam and head choice as well.
In other words we need more information about these parts.
Old May 14, 2012 | 02:44 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I would say between -50hp to +100 hp
I am impressed at this posts lack of information
Old May 14, 2012 | 04:19 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
You can't just "ballpark" with that information. You might as well draw numbers from a hat, that's how much power you're going to make. You haven't told us anything so there's nothing we can tell you. My guess is since you have NO clue what you're getting you'll probably lose power. I don't know ANYONE who just gives free parts away (that are decent parts). Even friends want money out of it, albeit a very good deal. $10 says you just helped him clear out more garage space with junk he had.
Old May 15, 2012 | 12:06 PM
91phoenix's Avatar
However very possible. However I would stay on the lower end of that scale.
Old May 15, 2012 | 12:19 PM
midias's Avatar
I used some quality software to generate possible gain from the combination you listed.
Estimated HP gain
38 Combination 1
48 Combination 2
-49 Combination 3
18 Combination 4
-2 Combination 5
74 Combination 6
99 Combination 7
39 Combination 8
26 Combination 9
88 Combination 10
-34 Combination 11
-45 Combination 12
95 Combination 13
-43 Combination 14
32 Combination 15
78 Combination 16
41 Combination 17
91 Combination 18
-8 Combination 19
92 Combination 20
57 Combination 21
60 Combination 22
-1 Combination 23
63 Combination 24
-17 Combination 25
45 Combination 26
-43 Combination 27
59 Combination 28
-31 Combination 29
-5 Combination 30
-44 Combination 31
58 Combination 32
40 Combination 33
74 Combination 34
63 Combination 35
36 Combination 36
69 Combination 37
-24 Combination 38
-36 Combination 39
24 Combination 40
13 Combination 41
-32 Combination 42
76 Combination 43
53 Combination 44
-40 Combination 45
-8 Combination 46
36 Combination 47
27 Combination 48
62 Combination 49
-45 Combination 50
-8 Combination 51
-4 Combination 52
91 Combination 53
26 Combination 54
52 Combination 55
2 Combination 56
-11 Combination 57
12 Combination 58
-3 Combination 59
-48 Combination 60
-38 Combination 61
5 Combination 62
57 Combination 63
23 Combination 64
18 Combination 65
74 Combination 66
80 Combination 67
1 Combination 68
49 Combination 69
66 Combination 70
-43 Combination 71
7 Combination 72
54 Combination 73
50 Combination 74
40 Combination 75
67 Combination 76
54 Combination 77
-17 Combination 78
96 Combination 79
32 Combination 80
99 Combination 81
47 Combination 82
27 Combination 83
36 Combination 84
35 Combination 85
-46 Combination 86
-50 Combination 87
18 Combination 88
75 Combination 89
-43 Combination 90
40 Combination 91
52 Combination 92
10 Combination 93
1 Combination 94
73 Combination 95
51 Combination 96
22 Combination 97
14 Combination 98
-21 Combination 99
-15 Combination 100
85 Combination 101
78 Combination 102
52 Combination 103
55 Combination 104
-18 Combination 105
43 Combination 106
50 Combination 107
35 Combination 108
73 Combination 109
-13 Combination 110
68 Combination 111
40 Combination 112
41 Combination 113
42 Combination 114
-37 Combination 115
9 Combination 116
-26 Combination 117
81 Combination 118
83 Combination 119
75 Combination 120
62 Combination 121
63 Combination 122
75 Combination 123
84 Combination 124
20 Combination 125
-17 Combination 126
70 Combination 127
67 Combination 128
20 Combination 129
0 Combination 130
-36 Combination 131
58 Combination 132
35 Combination 133
-42 Combination 134
-43 Combination 135
-2 Combination 136
30 Combination 137
69 Combination 138
-26 Combination 139
-9 Combination 140
-42 Combination 141
-11 Combination 142
-31 Combination 143
47 Combination 144
-18 Combination 145
-19 Combination 146
-2 Combination 147
50 Combination 148
50 Combination 149
52 Combination 150
30 Combination 151
71 Combination 152
-6 Combination 153
47 Combination 154
-12 Combination 155
-10 Combination 156
92 Combination 157
34 Combination 158
32 Combination 159
-14 Combination 160
-30 Combination 161
44 Combination 162
63 Combination 163
52 Combination 164
54 Combination 165
57 Combination 166
-17 Combination 167
20 Combination 168
83 Combination 169
-36 Combination 170
25 Combination 171
91 Combination 172
69 Combination 173
-33 Combination 174
-38 Combination 175
53 Combination 176
70 Combination 177
30 Combination 178
91 Combination 179
-17 Combination 180
54 Combination 181
94 Combination 182
-3 Combination 183
-48 Combination 184
74 Combination 185
-31 Combination 186
-13 Combination 187
28 Combination 188
-43 Combination 189
23 Combination 190
-36 Combination 191
98 Combination 192
-45 Combination 193
-10 Combination 194
17 Combination 195
-12 Combination 196
49 Combination 197
-31 Combination 198
-42 Combination 199
-32 Combination 200
63 Combination 201
-18 Combination 202
-25 Combination 203
-12 Combination 204
65 Combination 205
81 Combination 206
44 Combination 207
36 Combination 208
Old May 16, 2012 | 12:17 PM
Guest
Guest
Posts: n/a
All right ***holes. Thanks a million. Ballpark to me means using words like "hardly anything" and "considerable" and "decent". He had these in a boosted S10 running 10.9's. I saw the time slip. I will post it when I see him next. Why are you such dicks?
Old May 16, 2012 | 12:22 PM
midias's Avatar
You asked a question giving zero information and expected a response other than what was given?
But to be a nice guy I will answer your question. You will gain somewhere in between "hardly anything" all the way to "considerable" with a chance of falling right on "decent".
Old May 16, 2012 | 02:39 PM
Guest
Guest
Posts: n/a
Sarcastic and sardonic, but an answer. Thank you.
Old May 16, 2012 | 02:51 PM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
There's nothing ******* about it. You can't just give vague information like that and expect a serious answer.. like that, for example. Boosted S10. That means NOTHING. Boosted with what? What motor? what compression? what trim? What gears? What transmission? What car, even?
See what I'm saying? There's too many variables in that equation. I've seen cars run low 11's with modified "stock" heads... but it's in a 400 small block with a pissload of gear and a gutted interior. That doesn't mean you'll run 11's with same heads.
Our answer is simple. Figure out what you have, then come back and ask again. Serial numbers, part numbers, casting numbers, SOMETHING TO GO BY.. and we can help. Otherwise we're just rolling the dice and guessing.
Old May 16, 2012 | 03:00 PM
midias's Avatar
I gave you 3 answers all just as valid. Your question would be akin to asking "someone is going to give me a shotgun what model and gauge will it be?"
Old May 17, 2012 | 04:46 PM
91phoenix's Avatar
This is simple. It will be a brand starting with a letter A to Z and a gauge from .410 up through 10 ga. Ithaca 10ga. if you are selling it to me cheap. lol
To the OP I asked for numbers at the beginning knowing full well that the others who replied here (much smarter than I am) would need that information.
It is a mistake to think that anyone can give accurate information because you said the S10 was boosted and really nothing else. Boosted how? How much boost? What year s10. What weight S10? Now still back to the parts to know compared to what you currently have. I would bet the crankshaft will not be useable due to 2 pc rr main seal. If put together properly that boosted engine was put together and components chosen for the type and amount of boost. This could very well mean a loss of power based on what you have currently however I would bet a small gain from an increased compression ratio anyways.
I am hoping this helps explain why we still have no real information.
84z96L31vortec
Aug 20, 2017 12:16 AM
gta90
Sep 15, 2015 04:00 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
