305 Z28 Engine modification
Old May 14, 2012 | 05:16 PM
N_da_Mood's Avatar
Car: 1992 Z28 Heritage Edition
So I have had my Z for about a year now and am finally deciding to start some engine work. So my question is for a 305 what would be some basic engine modifications that everyone should do to there 305? Its Tuned port Injection. Id prefer the cheaper solutions first but all will do. So anything that will add some power but will just be all around good for the engine! Thanks!
Old May 14, 2012 | 06:11 PM
Phenom-1's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Re: 305 Z28 Engine modification
Basic bolt ons like k&n air n oil filters, NGK Sparkplugs, new aftermarket exhaust like Magnaflow or Flowmaster
Old May 14, 2012 | 06:13 PM
Phenom-1's Avatar
Engine: 5.7 TPI
Is yours automatic or 5sp ? You Could change the gears in the back
Old May 14, 2012 | 06:23 PM
N_da_Mood's Avatar
It already has K&N filters, brand new magnaflow exhaust just got it last week, and I just changed the spark plugs I didn't buy those but I bought expensive ones. New distributor cap, wires, rotor button. Small stuff like that but im looking for one step up from that. Its an auto.
Old May 14, 2012 | 06:31 PM
Phenom-1's Avatar
Engine: 5.7 TPI
Does it have the G92 code ?
Old May 14, 2012 | 06:34 PM
N_da_Mood's Avatar
No, I think that only came on the 5 speeds didnt it?
Old May 14, 2012 | 06:36 PM
Phenom-1's Avatar
Engine: 5.7 TPI
Nope, mines G92 and its automatic
Old May 14, 2012 | 06:37 PM
N_da_Mood's Avatar
hmm well mine does not then
Old May 14, 2012 | 06:38 PM
Phenom-1's Avatar
Engine: 5.7 TPI
What gear ratio do you have ?
Old May 14, 2012 | 06:56 PM
N_da_Mood's Avatar
Ya know I've not looked into it, its a stock rear end with posi, but I just got the car last year.
Old May 14, 2012 | 07:01 PM
Phenom-1's Avatar
Engine: 5.7 TPI
You should find out hopefully its the stock rear but if you have the G92 code then you probably have good gears but if you don't have G92 then you got the highway gears 2.73 not desirable for when acceleration is wanted.
Old May 14, 2012 | 07:07 PM
N_da_Mood's Avatar
I will check this weekend when I get home.
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
