1piece main seal replacemnet
Old May 15, 2012 | 04:27 PM
trafficlightguy's Avatar
Car: 1988 iroc
Engine: 350 30 over
Axle/Gears: Series 2 373
I know this question been asked a million and one time but, does the oil pan have to be removed, if so how high does the engine have to go up to get to the seal
I have long tube header and really don't feel like removing them again
Chris
Old May 15, 2012 | 04:48 PM
irocarter's Avatar
Car: 89 iroc
Engine: 5.7 trick flow heads t-ram
Transmission: wct5
Re: 1piece main seal replacemnet
no, you don't have to remove the pan.
Old May 15, 2012 | 04:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Don't have to remove the pan, but you do have to remove the transmission.
Old May 15, 2012 | 05:03 PM
GreenCamaro13's Avatar
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
i was looking at this too when i was checking mine, im guessing your car is leaking oil? before you do that check the distrubitor gasket, mine seemes to have been leaking oil from there, not sure if that IS the problem but it was fresh oil that was around it soo.. i will have to see once i get my head gaskets changed and heads back on.
Old May 15, 2012 | 05:54 PM
Car: 1988 iroc
Engine: 350 30 over
No I already rebuilt the motor but the seal is leaking, maybe I did not get it right the first time
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
Dragonsys
Sep 25, 2015 03:51 PM
