sbc water drain plug
Car: 1986 Iroc Camaro
Engine: 350+
Hi
Anybody know where i can buy a water drain plug for my engine as i purchased a second hand engine and the plug on it is missing its a chevy camaro and the drain plug is just under the exhaust manifold above the starter motor.
Do not know the size? Sorry
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: sbc water drain plug
Any hardware store, it's just a pipe plug.
If you want to be fancy you can put a petcock in there intead so you can drain the block any time you like.
Car: check
Engine: check
Transmission: check
RBob.
Engine: 350+
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Justin92GTA
Aug 27, 2015 11:16 PM
Dialed_In
Aug 20, 2015 01:45 PM
Wrong info guys ordered 1/4 npt not big enough more wasted money
