Vacuum Help
Old May 16, 2012 | 11:21 AM
Jcase350's Avatar
Car: 90 Camaro Iroc-z
Vacuum Help
I am working on a 90 Camaro 350 TPI. I just replaced the injectors and think I may have crossed a couple of vacuum lines. It is idling almost like it has a miss. Can anyone tell me where the vacuum hose from the throttle body goes to? Also, where does the line from the vacuum canister(behind drivers side headlight) go to? Also, the 2 lines that come off the EGR solenoid? I have following the vacuum diagram as best I can but want to double check. Thanks in advance.
Old May 16, 2012 | 05:54 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Vacuum Help
Bottom port ( vac ) on TB goes to canister purge solenoid ( then to canister )
Top port is PCV supply air to pass side rocker cover
the 2 lines that come off the EGR solenoid? .
One vac line goes to the EGR valve under plenum;
the other is the supply vac
Old May 16, 2012 | 06:27 PM
Jcase350's Avatar
Re: Vacuum Help
What about the vacuum line underneath the throttle body? Also what lines run to/from the check valve by the ignition coil?
Old May 16, 2012 | 06:44 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
Re: Vacuum Help
egr soilonoid... one to the egr valve the other to underneath trottle body
Old May 17, 2012 | 03:43 PM
Jcase350's Avatar
Re: Vacuum Help
Got those connected correctly....where does the vacuum port on the MAP sensor go...to the fuel pressure regulator?? One more...where does the 2 lines from the check valve next to the MAP sensor go? Thanks
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
timonator
Sep 30, 2015 12:52 PM
dusterbd
Sep 29, 2015 08:40 AM
