Locating my Fuel Pump...PLZ HELP ME!
Old May 19, 2012 | 05:05 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So on my 84 z28 carbed i was wondering if this is my fuel pump becuase I beleive its bad already, and i took some piks of it but I am not completely sure if this is it, and was also wondering where the filter is @, thanks!
">Name:  fuelpump5.jpg
AND ARE THESE THE FUEL LINES???????????
Size:  58.3 KB">Name:  fuelpump6.jpg
and i think this is the fuel pump, but not sure, but I am pretty sure that my 84 z28 is a mechanical pump.
Size:  45.7 KB">Name:  fuelpump4.jpg
File Type: jpg
File Type: jpg
Old May 19, 2012 | 05:18 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Locating my Fuel Pump...PLZ HELP ME!
Yes that is your fuel pump, what makes you think it is bad is it leaking gas?
Old May 19, 2012 | 05:35 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Im not real sure on the filter but follow the fuel line to the carb it might be on the carb, the few ive seen its on the front of the carb. Not for sure.
Old May 19, 2012 | 05:44 PM
calgutie's Avatar
Car: 1984 Z28
sweet, thanks, and yeah il do that with the lines, but i think its bad b/c it starts normally then when i go to park the car and tri to tunr it on th eengine trn over but it takes a lil longer for it to turn on so in other words it takes a couple of crankings, the other nite i literally was stock at walmart parking lot b/c the car wouldnt start and a budy of mine recommended changin the fuel pump and filter b/c i am lead to beleive that ther are the stock filter and pump from 1984.....
Old May 19, 2012 | 06:22 PM
Edwardgp's Avatar
Engine: 454-350
Well let us know what the results of this project are.
Old May 19, 2012 | 06:29 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Probably leaking plugs in the bottom of the carburator
main body draining the float bowl as car sits for a few
hrs-leading to long crank time to refill bowl and start.
This is a pretty common quadrajet fault,escpecially with
early '80s era q-jets-i had an '84 q-jet on my car for a
while that did the came thing,had to take carb off,clean
and use a little peening of the leakey plugs and some
epoxy sealer fixed the draindown problem and restored
quick starts.
Ghettobird52
Jul 5, 2024 11:18 PM
Dialed_In
Aug 20, 2015 01:45 PM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
