Idle problem
Old May 20, 2012 | 09:26 AM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
Idle problem
1991 GTA
350 TPI
Automatic
So, for the past couple of months, my car has had idle problems. Usually it starts and runs fine. On the morning commute it isn't too bad. On the way home, however, it idles very poorly. It's almost like the engine is going to putter out and then it surges to stop itself from doing so. A couple of times, the RPMs did drop to low and I had to restart the car. When I get on the gas, the problem seems to go away, until it gets to idle RPMs again.
I had a similar problem on another vehicle of mine (which really reved out of control) and that turned out to be the idle control valve.
Any ideas on what the problem is?
Thanks!
Bill
Old May 20, 2012 | 09:04 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Re: Idle problem
lol, but i would think IACV first, after that check i think vacc leaks, air filter(s), fuel filter would probably be my other first checks.
Old May 21, 2012 | 04:49 AM
wgripp's Avatar
Re: Idle problem
what's IACV? idle control valve?
Old May 21, 2012 | 09:12 AM
Black88Z's Avatar
Re: Idle problem
yes, idle air control valve
Old May 21, 2012 | 01:34 PM
danziger's Avatar
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
Re: Idle problem
Mine is doing the same thing and I thought it might be the ignition module going out. Free bump for more input...
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
