mechanic says my carbs to small
Old May 21, 2012 | 10:12 AM
burn0ut305's Avatar
Car: z28
Transmission: pro built 700r4 (road racing kit)
progress on my camaro has been slow, and i'm really regretting not putting a 350 in when i had my engine out however at the moment im stuck with this 305 and ill be damned it i wont get some power out of it. took it to the mechanic today because it bogs down when you floor it. His response was that the holly street avenger 570cfm is to small, and i should have left the quadra jet on it. opinions?
stock 305 with headers, intake, and the street avenger carb.
Old May 21, 2012 | 10:24 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: mechanic says my carbs to small
570 seems fine for a near stock 305
Old May 21, 2012 | 10:29 AM
burn0ut305's Avatar
Car: z28
what would be causing my motor to bog down, it feels like its got half the hp it use to. i realize its just a little 305 but it has very little hp
Old May 21, 2012 | 10:33 AM
midias's Avatar
It just sounds like it needs to be tuned. I run a 600cfrm on a 355 with no problems at WOT.
Are your secondaries opening correctly?
Old May 21, 2012 | 11:16 AM
burn0ut305's Avatar
Car: z28
will see what the mechanic says after today...
Old May 21, 2012 | 12:12 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Nah not too small at all, my boss has a 383 sbc that has 460hp runs with a 550cfm 2bbl. Your carb may need to be cleaned and tuned too.
Old May 21, 2012 | 12:26 PM
burn0ut305's Avatar
Car: z28
this is practically a new carb, less then 250 miles on it. Its been on the motor for a while now though, just has never been tuned. Really hope this mechanic does a good job.
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
gta90
Sep 15, 2015 04:00 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
