Car won't go past 4500 RPM.
Old May 24, 2012 | 06:38 AM
ScorchedBird12's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: TPI 5.0 V8
Transmission: 5-speed manual
Axle/Gears: Stock
So on the highway, I decided to downshift to third and I noticed that the engine once it hits 4500 it won't go any higher.
As soon as I got home, I revved it while parked and then it would 5500 which is where it should be. Before this I figured that the car started running lean when it hit the higher RPMs but with it redlining when parked I'm stumped.
I ruled out the Mass Air Flow sensor because from experience if something is wrong with that it won't even let me rev past 2500 on other cars so I assume it's the same here.
Any ideas?
Old May 24, 2012 | 07:52 AM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Re: Car won't go past 4500 RPM.
The amount of fuel required under load is much higher than what is required to rev out in park. Sounds like you might be running out of fuel. Check your filters and fuel pressure.
Old May 24, 2012 | 10:59 AM
brodysZ28's Avatar
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
Could be valve float too, how many miles are on the engine? A compression test could tell you something too...
Old May 24, 2012 | 09:05 PM
mintc's Avatar
i just had the same prob with my 91, after i verified i was getting plenty of fuel , i checked the plug wires, then cap and rotor, coil , then the icm, after all of this was checked and replaced the stuff that looked like it could use it, i still had the problem so i tooked her to the muffler shop and had then but a new cat on it and that was the cause of my prob , good luck to u
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
ZsTransAm
Aug 11, 2015 07:30 PM
novaderrik
Aug 10, 2015 12:44 PM
kyle5647
Aug 7, 2015 03:08 PM
