Cooling both fans to run at same time
Old May 29, 2012 | 04:28 PM
BayAreacustoms's Avatar
Hi,How can i wire both fans to come on together.maybe when i turn on the ignition?
Its a 89 iroc 305 tune port,Thanks
Old May 29, 2012 | 09:04 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Cooling both fans to run at same time
Why would you want to do that?
There is a reason for allowing the engine to get up to operating temp before the fans turns on to maintain that temp.
Old May 29, 2012 | 10:36 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
the current surge of both fans starting together might
cause the ignition to hiccup for a second,so best way
would be to run the two fans connected together using
an electronc varible speed fan control so the fans ramp
up to speed when triggered,avoiding the startup current
surge.
Old May 29, 2012 | 10:40 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by 8t2 z-chev
best way
an electronc varible speed fan control.
And a temp switch in the engine so they come on at correct temp ; not when engine stone cold
RazorN8
Jan 7, 2022 11:44 AM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
Leggman1
Aug 6, 2015 04:15 AM
