Distributor Question about advancing timing...
Old May 30, 2012 | 02:35 PM
Rocket-Doc's Avatar
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
So in rebuilding my engine it appears that I tosed my old dizzy...
I was rummaging through the 120 options I have and at this point am wondering what route to go.
The EBL controls the advancement of timing, so is there any reason to get a vacuum or mechanically advanced distributor? Isn't that counter productive. The only reason I ask is every HEI distributor that I come across has been vacuum advanced, do I just not connect a vacuum source if I still want the EBL to control it?
Wanted to go HEI to clean up the engine bay as much as possible, but it just seems easier to go stock.
Thanks for the help in advance...
Old May 30, 2012 | 02:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Distributor Question about advancing timing...
The car wouldn't run with a mechanical distributor.
Old May 30, 2012 | 03:09 PM
Rocket-Doc's Avatar
Such a verbose response from a moderator... Wonderful explanation.
Old May 30, 2012 | 06:02 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Plus it's not totally true, either. But let's keep it simple. Lazy me just opened my Summit catalog, and I don't see 120 options that'll work with your stock computer. In fact, without bothering to go to the various websites, all I see is MSD's 8366. And I wouldn't pay $280 for that, either.
Old May 30, 2012 | 06:59 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Your proposed vac/ mech dist has no provision for ECM control
You need a computer controlled HEI with the wiring connection for SA control from the ECM
every HEI distributor that I come across has been vacuum advanced, .
DUI is about the only new source of computer controlled HEI these days
http://www.summitracing.com/parts/DUI-12611BK/
otherwise used CC HEI dist from a L98 Vette (TPI ) or early '80's F-Body HEI
Cheaper alt is the small cap /remote coil setup as used on later F-Bodies and 87 -95 TBI trucks
Old May 30, 2012 | 07:56 PM
Rocket-Doc's Avatar
Got it, so I have 3 choices:
1. Use a stock dizzy. Keep EBL
2. Use the DUI dizzy. Keep EBL
3. Choose vac or mech advance and go carbed...
Thanks...
Old May 31, 2012 | 08:15 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The mentioned MSD 8366 distributor will also work. Me, I'd find a distributor in decent shape in the JY and clean it up and use it. Most importantly, is to use a GM ICM.
If you use the small cap distributor one of the "Made in USA" house brand (jegs/summit) oil filled canister coils is a good choice.
RBob.
Old May 31, 2012 | 09:37 AM
Rocket-Doc's Avatar
@ Atilla, 120 was a bit of an exaggeration yes, but I was on google searching not just doing a website crawl.
@ RBob, got it and thanks.
Caspar
Jun 19, 2016 11:19 PM
86IROC112
Aug 17, 2015 07:57 PM
86IROC112
Aug 17, 2015 02:00 PM
redmaroz
Aug 16, 2015 11:40 PM
midias
Aug 15, 2015 05:07 PM
