89 Iroc with 11,000 won't start please help
Old Jun 3, 2012 | 07:11 PM
mapwpdiroc's Avatar
Car: 1990 IROC-Z Convertible
Engine: 5.0
I have a low mileage stock car that was throwing a MAF code this is the 3rd MAF in 11K. So before put 3 rd one in I cleared code and left the second one in and I went to get on it and car fell on its face stalled out. I could not start car that night, I tested for fuel pressure at rail and there was. I pulled a plug and checked for spark it was there, the car would crank but not run. I left it and next morning to be sure I brought 3 gallons of gas to be sure I had gas in case gage was dead it said last night I had 1/4 of tank and when I opened gas cap i had serious vapor lock. I then disconnected MAF and battery for a couple minutes cleared codes and car started right up. I left MAF disconnected and drove home. Next day I then put in new MAF and car started right up. Ran it for twenty minutes and I shut it off no codes seemed fine. I then went to start and it would not. I checked fuel pressure and it had 42 pounds of pressure on gauge. Next day I was having it towed to mechanic and it started ran it for ten minutes and then trying to load on flatbed it died n would not start. Mechanic confirmed spark and fuel pressure he thought for sure computer. Pulled one in it out and saw it was not original computer and had a hypertech chip I knew that 160 thermostat is in it. So third computer in 11K car still did not fix car. Thoughts????
Old Jun 3, 2012 | 07:16 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 89 Iroc with 11,000 won't start please help
OHM check the injs. are you running a K&N?
Old Jun 3, 2012 | 07:20 PM
mapwpdiroc's Avatar
Engine: 5.0
Yes K&N s n injectors where checked the week before when I first saw MAF code and all good
Derick15
Sep 17, 2016 05:28 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
mustangman65_79
Aug 11, 2015 03:17 PM
