front drive distributor
Old Jun 4, 2012 | 03:36 PM
89blackm's Avatar
i saw this for the first time on saturday on horsepower tv.....i thought it was pretty cool and was wondering your guys opinion/thoughts on them???
Old Jun 4, 2012 | 05:09 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: front drive distributor
only relevant if you have a firewall clearance problem
With todays technology better to run LS type coil per cylinder setup
http://www.eficonnection.com/eficonnection/24x.aspx
Old Jun 5, 2012 | 07:16 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
At 1000+ dollars, is it really worth it? I know cars running in SuperStock use them because they'll move the engine back as far as it will go for weight distribution and to get more clearance, they'll switch to a front mount distributor.
You'll still need to add an oil pump drive so that the camshaft can drive the oil pump. That costs extra.
My BBC is pushed back and I still have enough room for a normal MSD distributor. I do however use a crank trigger.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
jklein337
Sep 19, 2018 06:23 PM
kyleb24
Aug 15, 2015 08:24 AM
