comp cam break in
Old Jun 6, 2012 | 09:57 AM
camaro211z28's Avatar
Car: 92 camaro RS
Engine: vortec 350/396
comp cam break in
i just put a flat tappet comp cam in my 92 camaro.. the intructions say use 15w-50 non synthetic oil and a zinc and phosphorus additive. i cant find any 15w 50 around my area and if i do its synthetic. so i called comp cams twice and spoke to two different techs. one said to use valvoline vr1 10w 40. i cant find that either. and the other tech said use 10w-30 or 15w-50 but use the additive and he also said every oil change use an additive also. that sounds a bit much to me every oil change. this is my first cam break in so thats why im not to sure of what oil and additive to use and i dont want to screw it up.
Old Jun 6, 2012 | 10:30 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: comp cam break in
10W-30, 15W-40, 20W-50, or whatever heavier weight you can find should be fine for oil. Additive at every oil change is a good idea.
Old Jun 6, 2012 | 11:42 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
I was taught and have followed the practice of using straight weight engine oil SAE 30, SAE 40, with NO DETERGENT. It has always worked fine for me. The reason for the non-detergent oil (as it was taught to me) is that you don't want detergent to wash the assy lube from the parts, any sooner than necessary.
A zinc additive will help, both break in and life. Doesn't Shell Rotella (or other OTR truck oils) still have a lot of zinc in it?
I personally feel that if you use a zinc additive, the oil you use probably doesn't matter too much.
Old Jun 6, 2012 | 11:54 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Pretty hard to find a non-detergent oil these days, but I don't see detergents having much of an effect on the break-in lube. Straight weight would be SAE 30 or SAE 40, there's no 30W or 40W grades.
Diesel oils supposedly still have more zinc than gasoline oils, but not as much as they used to.
Zinc tends to degrade catalytic converters over time, so maybe don't go too overboard with it if you still have one.
Old Jun 6, 2012 | 11:56 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
I used a diesel 15W-40 plus a bottle of the Comp additive both for break-in and every regular change. Oil choice was limited to what I could find locally that still has some zinc in it.
Had occasion to pull a couple of lifters after 1000 miles and 2 oil changes. Looked fine, nice even polished surface, crown radii were still as-new.
Old Jun 6, 2012 | 12:06 PM
Engine: LT1, L400
You're right on the SAE 30, etc. Thank you for the correction there.
I agree that non-detergent is hard to find...and also agree that the reasoning for using it is dubious...but posted b/c it has worked for me.
Old Jun 6, 2012 | 12:20 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Joe gibbs BR oil is 15w50 with high levels of ZDDP on phosphorus.
Old Jun 6, 2012 | 12:40 PM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
I've used comp cams 10w-30 break-in oil on the last few flat tappet motors with great results. It is best to use an oil with the ZDDP in it already for break-in.
Old Jun 6, 2012 | 03:29 PM
Car: 92 camaro RS
what brand of diesel 15w 40 did you use? i didnt think they use zinc in any oil anymore, itd be cheaper to use the 15w40 or 30w oil and some zinc additive. i found the break in oil and zinc additive at a local speed shop. but its 7.99 a qt of oil and 13.99 for the additive. but i cant see spending 50+ dollars on oil im only going to use for 30 minutes.
Old Jun 6, 2012 | 03:35 PM
LilSki's Avatar
Car: 85 Trans Am
Spend the money unless you want to spend much more on a motor rebuild after you wipe out the cam.
Old Jun 6, 2012 | 04:00 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Valvaline VR-1 specifically says on the bottle that it has high levels of ZDDP for flat tappet cams.
Old Jun 6, 2012 | 04:09 PM
Car: 92 camaro RS
I cant find the valvaline oil
Old Jun 6, 2012 | 06:56 PM
NY87Iroc's Avatar
Car: 1987 Iroc convertible
Axle/Gears: 3.42 posi
THIS!!
Old Jun 6, 2012 | 07:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
For the cam break-in:
http://www.amsoil.com/storefront/brk.aspx
After the break-in:
http://www.amsoil.com/storefront/zrt.aspx
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
Strick1
Sep 4, 2015 07:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
