Instrument Panel Help Please
Old Jun 6, 2012 | 07:38 PM
jollythought's Avatar
Car: 1983 Trans Am
Engine: Lu5
Transmission: TH700R4
Background Info: 83 T/A Lu5 CFI. Sat for a couple of years and I am trying to get it to daily driver shape. Before it sat I remember all the gauges working fine, and then the temp went out, not too much later the fuel gauge wouldnt read right. Then the speedometer needle started bouncing.
Now as far as I know none of the guages read properly, the backlights dont work, and the dummy lights dont work except the brake light (barely). The battery gauge might be the only one that is ok.
I would really like any kind of advice/ starting points rather than go in blind. I also have a Haynes and Shop manual, but they are not always very detailed..
Thank you in advance
Old Jun 7, 2012 | 06:01 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: Instrument Panel Help Please
Wondering if corrosion may have set in. Corroded ground wire connection somewhere. Is the battery in good shape and fully charged?
Old Jun 7, 2012 | 06:33 PM
Car: 1983 Trans Am
Engine: Lu5
No, the battery isnt very good. I've had to charge it a few times the past couple months. Would that affect the gauges?
Old Jun 7, 2012 | 08:59 PM
jtsk's Avatar
yes, it's possible.
Old Jun 7, 2012 | 09:25 PM
Car: 1983 Trans Am
Engine: Lu5
Ok, well its about time for a new battery and I'll check the ground wires.
Thank you for the advice
Old Jun 7, 2012 | 09:33 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Sounds like it could be a ground related to the cluster, or the wiring to it. This is especially if the lights are affected as well.
I have also seen where the flex circuit board has cracked before and created an open where half of the lights went out. I made a temporary bridge with a piece of wire for that one, but I don't know how long that lasted though.
Old Jun 8, 2012 | 06:46 PM
Car: 1983 Trans Am
Engine: Lu5
I dont think mine is cracked but I'll double check, Thank you
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
FormulaEngland
Sep 30, 2015 01:50 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
