pcv question
Old Jun 8, 2012 | 06:49 AM
budget builder's Avatar
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
pcv question
if I dont have any emissions stuff do I absolutely need to use the pcv port on a edelbrock 1411 carb? its going in a 89rs on a rebuilt 355 flat tappet with no emissions?
Old Jun 8, 2012 | 07:07 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: pcv question
Don't hook up the pcv and you'll have plenty of emissions
Old Jun 8, 2012 | 07:29 AM
Car: 91RS
Re: pcv question
10-4 plug it and
I just wanted to know that it wouldn't hurt the engine
Old Jun 8, 2012 | 09:28 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Re: pcv question
I suppose you could replace it with a crank case breather.
Old Jun 8, 2012 | 09:46 PM
Toofpik's Avatar
Car: 91 RS
Engine: carbed 305
Axle/Gears: 3.42 w/posi & disc brake
Re: pcv question
There was a really good article on here or on another chevy site on why its important to have positive crankcase ventilation... Many people think its just for emissions and thats not the case, PVC keeps the engine's internals clean and keeps it from gunking up... The engine benefits from having gasses in the crankcase sucked out and recirculated...
Old Jun 8, 2012 | 10:40 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: pcv question
Why would you want to not have it? The whole system is a single hose, a small breather, and an unnoticeable valve. Cleaner engine and less crap in the air, the benefits have got to outweigh any possible downside I can think of, which is none.
Old Jun 8, 2012 | 11:22 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: pcv question
Why would you want to not have it? Cleaner engine and less crap in the air,
"the air circulates around the interior of the engine, picking up and clearing away combustion byproduct gases, including a large amount of water vapor which includes dissolved chemical combustion byproducts, then exits through a simple baffle, to trap oil droplets before being drawn out through the PCV valve, and into the intake manifold.
A plugged or malfunctioning PCV system will eventually damage an engine.
A engine with a poorly-maintained PCV system will eventually become contaminated with sludge,
Old Jun 9, 2012 | 12:13 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: pcv question
Originally Posted by budget builder
10-4 plug it and
Woops, think my carefully crafted sarcasm was lost
Old Jun 9, 2012 | 12:43 AM
Re: pcv question
Yeah, less crap in the air. Hmmmm
Old Jun 11, 2012 | 09:36 AM
Car: 91RS
Re: pcv question
holy crap I completely got lost on that one ok this is what i'll do pcv in one side and push in oil cap in the other. thanx and by the way yeah i'm a complete rookie
1fast91
Sep 8, 2015 01:48 PM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
