Stumped, yet again. Phantom 42 and 51
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
The car was giving me symptoms of a bad coil, it would usually run ok but would occasionally lose all its power, sometimes at a stop the rpms would start climbing, and i would really have to hold the brake down to keep the car still (never got bad enough i had to put it in neutral or shut it off). It would even stall out sometimes, then when i go to restart it it starts fine and acts like theres no problem. For a while it never would throw a code, then it finally did. Gave me 42 and 51.
Code 42: Fault at electronic spark timing circuit OR Fault at direct ignition system OR Fault at fuel cutoff relay circuit
Code 51: PROM error
The other day it stalled on me 3 times, 2ce within about 3-5 miles. Each time after it stalled, it didnt want to restart immediatly, but after a few minutes it would, and it ran ok again. I replaced the coil with an msd coil and it seemed to help for a little while, but it stalled again. I ran the codes, 42 and 51.
Replaced the ESC because i read thats a common cause of 42, hasnt stalled (yet, knock on wood!!) but just gave me the ses light (42 & 51). Shut it off, restarted it, and still had the light. I shut it off again, came back about 15min later and started it, no light and no problems.
I have noticed that almost every time (to be honest, im almost positive its been EVERY TIME) i get a code, 51 pops up with it.
I have ohmed my injectors several times, warm and cold, and they all were within spec. I havent done it in about a month though, so i will do this AGAIN, just to be sure.
Im not very familiar with PROMS, i know their function but dont know much about them. If its giving me 51, what can that mean?
Thanks for the help
Code 51: PROM error
Thanks for the help
Re: Stumped, yet again. Phantom 42 and 51
Theres really no one with any suggestions here? Still having the problem and would appreciate the advice..
Car: 1989 Camaro RS--
Engine: MPFI
According to the service manual, 51 is accident detected. History code diagnosis. I have the book right in front of me. I am still trying to learn how to read this huge book. I can scan the whole page for you tomorrow if you like and post it. Tells a lot more about it. How to clear and what it all means.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
With seeing the code 51 you may have a memcal issue or a ecm failure. The 1227165 ecm while running you can tap on the ecm this my flex the circuit board to duplicate the condition. I havent seen too many memcals fail over the years but did have one a while back have a bit flip causing the code 51.
