Location of ignition module
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Location of ignition module
if it is a 85 hei coil in cap or 87 up remote coil small cap are both located in the distributor. It's advisable if you going to replace the icm replace the pickup coil at the same time. Rotate the engine to tdc not the position of the rotor and pull the distributor. You will need to use the thermal paste included with the new icm. I always use acdelco parts or ignition electrical parts they maybe made in singapore, mexico or canada but there quality control is better than others.
Hotrodboba400
Dec 10, 2019 07:07 PM
